battery test failed note 10 plus.
(Topic created on: 05-17-2020 05:10 PM)
batking33
Galaxy Note
Never had any problem with battery. But somehow it failed the test. I factory reset the phone and just didn't update any apps... from galaxy store and battery even improved a little bit... but it's still saying the same thing.
Also found this older post about same issue
I don't just wanna take phone to service center yet.... because all they wanna do.. will be replace the battery. Even though it will be under warranty but I don't want them to fix it unless it is really an issue.
Last time I went to service center..  they told me they want to change my motherboard because I was unable to update my phone with smart switch pc... i was using the original Samsung cable that came with note 10 USB c to USB c but then after coming back from service center... i though why not try with usb 3 to usb c that came with one plus and it works perfectly.
Any suggestions are welcomed
13 Comments
Dilli
Galaxy Note
just ignore this notification pop up. This is a great example of how Samsung is inducting bloatware.🤔
immi007
Galaxy Note
That is not reliable.
how is your Battery doing in real life usage.
better you charge till 80% and reduce battery usage apps....
Not applicable
Galaxy Note
are yeh problem mere saath bhi hua hai aur abhi tak hai iska koi solution nahi hai
immi007
Galaxy Note
acha
