Note10+ Instant battery drain issue
(Topic created on: 12-10-2020 04:00 PM)
adunwell
Galaxy Note
Hi, I have a Note10+, its only 8 months old and the battery has started to instantly drop from around 50% to 0%. Would I be correct in thinking that the battery has failed?
6 Comments
S_Kumar73
Galaxy Note
It may be due to some rogue apps. try factory reset once. Still if u facing the same issue then the battery will be the problem
Ehsank
Galaxy Note
i suggest you to if you not done yet then do some settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
1. Settings>Connection>more connections settings> disable nearby device settings.
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> go to these 3 options below on by one
6.  Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will  shared data to show recommendation and suggestion which also cause battery drain
7.  Go to settings > account and backup> account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
Ehsank
Galaxy Note
if my given settings/comments will work for you then you can accept as solution by CLICKING on 3DOT at my comments
Arzee19
Galaxy Note
thanks for ur tips...
Galaxy Note
Facing same battery issues...
cs-member13
Expert Level 4
Galaxy Note
Dear Samsung Member,
We apologize for the inconvenience caused to you. To resolve battery issue kindly follow the below given step:-
- Battery optimization:- Settings > Select Device Maintenance/Device Care>Optimize>Optimize all options like Battery, Storage and Memory
For more information on battery drainage please click on the link below:-
http://www.samsung.com/in/support/skp/faq/1101689
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report/ask question). Kindly send us the screenshot (which apps are consuming most of the battery).
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
