battery issue
(Topic created on: 10-31-2020 08:20 AM)
Kabhilan_Sundhar
Galaxy Note
After updating my note 10+ October security patch my phone is slightly slows down and my battery too. Kindly solve this issue.
4 Comments
ketani72
Galaxy Note
Make sure that you restart your phone after the update is done.
Ehsank
Galaxy Note
please do these steps
A. Wipe Cache Partition.
Steps to perform.
1) Turn off the device.
2) Press and hold the Volume Up key and the spower button.
3) When the Android logo displays, release all keys.
4) Press the Volume down key to navigate and select "Wipe cache partition".
5) Press Power key to select. When the wipe cache partition is complete, Select Reboot System.
6) Press the Power key to restart the device.
B. Reset App Preferences.
Settings >Apps> Tap on Top Right 3Dots and select Reset App preferences.
Ehsank
Galaxy Note
if you not done yet then do some settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
1. Connection>more connections settings> disable nearby device settings.
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> go to these 3 options below on by one
6.  Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will  shared data to show recommendation and suggestion which also cause battery drain
7.  Go to settings > account and backup> account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery?)
10. Google >click on 3dot at right top corner>usage and diagnostics >off this option.
cs-member13
Expert Level 4
Galaxy Note
Dear Samsung Member,
To resolve "Battery drainage" issue kindly click on the link below:
http://www.samsung.com/in/support/skp/faq/1101689
And to resolve "phone working slow" issue kindly follow the given link: https://www.samsung.com/in/support/mobile-devices/how-to-restart-the-device-when-freezed-or-hanged/
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report).
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
