battery issue
(Topic created on: 01-08-2019 03:38 PM)
Rahul2016
Galaxy Note
Hi, i am facing battery problem from last 5 days. My phone battery drain automatically. It hardly give 10 hours backup in standby mode. When i see the battery usage i found android system used 50% of the battery.
5 Comments
Rahul2016
Galaxy Note
i don't want to go to the service centre for fresh software installation.
swapbiswas
Galaxy Note
which phone are you using?
Rahul2016
Galaxy Note
samsung note 9
admin_
Galaxy Note
We apologize for the battery issue facing in the device.Performance of battery depends on various factors; any third party application, software glitches may cause trouble. Kindly follow below mentioned steps to overcome the issue.
1) We recommend you to charge you handset with original wall charger that came with your handset sales pack.
2) Kindly clean the charging point of your charger and battery with a dry and soft cotton cloth to remove unwanted accumulation of dust/waste material.
3) You can also check the charging process while device is in switched off mode.
4) We also suggest you to charge your handset with alternate Samsung Approved charger to exclude the possibility that current charger is not the root cause of failure.
5) Check whether Bluetooth, WI-FI, GPS, Bluetooth, NFC / S Beam, Tethering and Portable Hotspot is turned off when not in use.
6) Check whether the brightness of the device is set to minimum.
7) Smart Features in Flagship phones like Motion UI, Smart Stay, Air Gestures, and Screen Mirroring / Smart view etc. will drain battery considerably.
😎 Check Power Saving Mode (If available)
9) Auto Sync of E-mails, App data etc. will drain battery.
10) Multiple Applications running in back ground will drain battery power.
11) Network Fluctuation also drains battery.
12) Minimizing the back-light time would save battery.
13) Follow the standard charging procedure (i.e. charge a fully discharge battery in Switch-off mode up to 150 minutes.)
14) Periodic Software Update through KIES, FOTA or Smart Tool is intended to improve the battery life as well.
• (Setting>>About Device>>Software Update>>Update) update using 4G/3G/ WI-FI connectivity.
15) Check by Go to setting>Application Manager>Running>Stop downloaded application when not in use.
16) After doing the above procedure, kindly restart your device and check the performance.
17) Check the issue in the safe mode.
Be sure to hit ♡ when you find an answer that works for you. For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url https://community.samsungmembers.com/en_IN#/
Rahul2016
Galaxy Note
1. i have checked the battery in safe mode also. it hardly run for 11 hours in safe mode. 18 to 20% battery drain in night after disable all application
2. i have formatted my phone and didn't intstalled any third party application still draining of battery continue
3. i hve updated the software. now i m using pie with android one ui. still same battery problem
4. i am using power saving mode. still battery issue
5. already spoke to ur customer care. she took my phone thru web and checked also. still battery issue.
