WiFi connection problem
(Topic created on: 03-12-2018 06:59 AM)
bug101
Galaxy Note
my galaxy note 8 is recently having problem with wifi connection. On starting wifi it gets connected to network then message comes checking quality of connection then gets disconnected. passsword is correct. Please suggest remedy
2 Comments
jikzzplr
Galaxy Note
wifi sensor are very weak its shits....
admin_
Galaxy Note
Thanks for being a part of Samsung community. We would like to inform you kindly follow the steps below to resolve your concern:-
- Navigate to apps >> Settings >> Apps >> Tap on three dots >> Reset app preferences.
- Please run your device in safe mode.
- Navigate to settings >> General management >> Reset >> Reset settings.
Be sure to hit ♡ when you find an answer that works for you. For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
