Resolved! Solved
Slow Wifi problem on Note 10 +
(Topic created on: 09-04-2020 11:00 AM)
aayushkhajuria
Galaxy Note
I recently upgraded to a new broadband connection with 50 mbps plan. But since then i started noticing that max speed that i could get on my note 10+ was 30-35 mbps. First i thought it is my router because devices connected with lan get full 50 mbps. But then i tested other old mobile phones at my home like s8 and a8 2018 they both get 45-50 mbps everytime. Then when i googled the problem i came to several others also face the same problem and some of the solutions suggested were of no use after reseting network settings or clearing cache partiotion from recovery i do get 50 mbps on speedtest but only for 10-20 minutes or should i say after 3-4 speedtests the 5th one again goes back to 20-35mbps always even with full wifi strength.
I hope to get a solution and want to know how many otgers have the same problem. Kindly help if you can i feels bad when a expensive mobile phone
Comes out slower than a mid range 2-3 year old phones.
Thanks in advance.
I would like to add that it was since i upgraded to 50 mbps broadband that i started noticing the slow speed because before this is used to think the old broadband is slow never considered it might be the phone.
Resolved!
Galaxy Note
what do you mean by delete network when i reset network setting it deltes all the known networks anyway. this helps with speed for about 10 minutes. do you think resetting phone might help cause i have a lot of data so i dont want to reset if not necessary.
Galaxy Note
just for your referense one is pic of s8 running same speedtest and 1 is screenshot from note 10+
only 1 device was connected to wifi when speedtest was run i also unplugged all lan cables to get best speed on speed test. as you can seegalaxy s8 always gives the speed equal to lan cable bro i dont how but all the time everytime. .
these speedtest were run from same place one after the other on same app so i dont know what else can be a problem then a software or hardware issue on note 10 + sorry for bad english im typing it as fast as i could
Galaxy Note
it is really disappointing and i was going to buy a new phone have beeen loyal to samsungsince 2013 i think but now i cant if i cant find solution to this then samsing phones are not worth i bought this guy at launch for 80k now i get to know it is not able to compete with mid range phones for wifi speed
Dilli
Galaxy Note
Take your phone back up without network and restore to factory default. After restore then add network. If still there is issue then visit SC if you can
Galaxy Note
ok bro i will try now and post back if i get some improvement . but you saw the pics right ? lan like speeds aall the time on galaxy s8 and a8 ? my plan is 50 and the old mobiles always get minimum 45 ans max 52
Dilli
Galaxy Note
https://youtu.be/MC8QTfzVq4Y
do this troubleshooting steps.
Galaxy Note
factory reset also did nothing still getting 20 to 28 mbps on this phone where as other are still getting almost 50 at almost all times
Dilli
Galaxy Note
Try your friends network and check what speed you get if situation is same then you have to visit SC .
Galaxy Note
You can go to samsung service center and get firmware re flashed of Note 10+.
Galaxy Note
my phone is out of warranty period i dont think thell do anything
