Note 9 screen color problem
(Topic created on: 09-06-2021 05:50 PM)
noman7
Galaxy Note
From 3rd september (4 days after security patch update) I m experiencing that my note 9's display color is not accurate....Highlight is increased.....Is there anyone who's experiencing the same.....What should I do now.....
#samsungnote9 #displaycolorproblem
6 Comments
AlphaTrion
Galaxy Note
If its some green/yellow tint issues, those issues are common in samsung devices since 5-6 years.
They haven't done anything to prevent it from happening for newer devices too.
The only solution is to replace the display according to samsung.
Never choose samsung again.
noman7
Galaxy Note
No I m facing only high highlight screen problem....
Bibin2801
Galaxy Note
Any solution for this I'm also facing the same issue
noman7
Galaxy Note
Yeah I received some official suggestions :
1. Adjust the brightness (didn't work)
2. Check device in safe mode (didn't work)
3. Software update (my phone's software is up to date)
4. Reset the device (now I m going to reset my device...देखें क्या होता है....Hope it works )
Galaxy Note
Go to service center and tell them its caused by update. They may change it for free.
Galaxy Note
Dear Samsung Member,
We apologize for your inconvenience. We request you to kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
