MaheshKumarS
11-25-2018 12:37 AM in
Galaxy Note
I have been using Samsung Note9 from the day it was launched in India. Though it is 4000 mAH battery it gets discharged with in 12 hours, though it is i power saving mode.
5 Comments
SanjuIndia
11-25-2018 12:44 AM in
Galaxy Note
Dear it's sufficient for Android Smartphone...
immi1
11-25-2018 03:16 AM in
Galaxy Note
taking more bettery if always display is on , wifi is on and unused apps ....u have to discharged your phone completely and charged on Airplane mode ....after that restart your phone and will be happy with your phone bettery
GalaxyTeam
11-25-2018 09:46 AM (Last edited 03-14-2019 02:16 PM ) in
Galaxy Note
vødka
11-25-2018 10:21 AM in
Galaxy Note
You can maximize the battery back up by following few points :
● Make sure that your phone is completely charged whenever you charge it. To get the best out of your battery.
● Make sure, Wifi is turned off when not in use.
● Turn off GPS when not in use.
● Turn ON the Power Saving option in settings.
● Turn off your Mobile data like 3G or 2G when not in use.
● Keep an eye on where your battery is consumed with the help of Battery Option in Settings as shown above in the pic.
● There is a probability that your Android firmware may be malfunctioning. Update or Re-install your firmware to get over with battery issues.
NOTE :
● These points are applicable to most of the Samsung smartphones running on Jelly bean 4.1 and above based Android System.
● The settings and options can change in due course of time, please refer to your user manual for more details.
Thanks for sharing your experience with the Community! Thank you so much for taking time to write us. We value your trust, and we will do our best to continue to give you the kind of service you expect.
We appreciate your loyalty, thank you for sharing your concerns with the Community!
Be sure to hit ♡ when you find an answer that works for you.
follow us for more info.
NOTE :
admin_
11-27-2018 05:12 PM in
Galaxy Note
Thank you for Joining Samsung community. We would recommend you to follow some troubleshooting steps in order to further isolate what you may be experiencing in your device. Find the troubleshooting steps on the provided link http://www.samsung.com/in/support/skp/faq/1101689. Please let us know what steps you have taken and if you have noticed any changes or improvements as this will help the Community to provide you further troubleshooting steps without repeating any procedure which you may have already followed. Be sure to hit ♡ when you find an answer that works for you.For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
