Note 8 network problem
(Topic created on: 10-21-2018 11:07 PM)
Rikki1581
Galaxy Note
After update October security patch in note 8 VLOTE note working
4 Comments
v3nom
Galaxy Note
I would kindly suggest you to follow this steps
Reboot your Galaxy Note 8 (soft reset).
One of the first steps in troubleshooting software-related issues in mobile devices is a soft reset. It can resolve issues like random crashes, device locks up, unresponsive apps and other relevant symptoms without affecting data and personal information stored on your phone. Here’s how it’s done:
Press and hold the Power button until the Power off prompt shows up.Tap Restart from the menu options.Tap Restart again to confirm.
Give your phone up to 90 seconds to complete the reset. After that, check and see if your phone is already getting stable signal.
Hope this helps you out ❤️💯
Rikki1581
Galaxy Note
Thanks Bro
pankajur
Galaxy Note
https://youtu.be/aSuj0FXUgHI
admin_
Galaxy Note
Thank you for sharing your concern. The relevant department will serve you better, if you can provide logs/video within 15 minutes of issue occurrence by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports). Be sure to hit ♡ when you find an answer that works for you.
For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
