Note 8 hanging problem
(Topic created on: 11-15-2017 10:27 AM)
sk619
Galaxy Note
why does the note 8 hangs and then crashes. it takes about 15-20 mins to restart even if I try to force start it with different button combinations.
there is some problem with the dialer because its the second time I had this issue in a month.
9 Comments
AnkurBansal
Galaxy Note
Please update your device to the latest software. This problem was common and a update might be rolling out very soon.
sk619
Galaxy Note
It is updates my friend
AnkurBansal
Galaxy Note
then please wait for a new update.
admin_
Galaxy Note
Thank you for your query. The relevant department may serve you better/speedily, if you can provide logs/video by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports). Be sure to hit ♡ when you find an answer that works for you.
sk619
Galaxy Note
can't provide a video because the phone freezes/hangs completely
Ani24T
Galaxy Note
If you are using a MicroSD card, remove it and try using without the card for few days and check if it still hangs.
sk619
Galaxy Note
I am not using a SD card, and the phone memory is almost free except for the OS installed. I haven't even saved any songs or videos or anything in the phone yet.
Ani24T
Galaxy Note
Try a factory reset.
MSoHaiL
Galaxy Note
Even i face this issue it completely freezes. Even facotry reset doesnt work.
