Note 8 battery issue
(Topic created on: 11-17-2018 11:43 AM)
SuperSU
Galaxy Note
My phone is 1 year old. I think after its last update it is showing a strange behaviour. Its battery will behave normally from the range of 100% to 20% but after hitting 20% it will start dropping @ 1% per 3 sec. So within a minute phone will shut down. But above 20% it works fine with a good battery backup. Also, nowadays this 20% has gone to 30%.
Why is this happening? I think it can't be battery problem else it would show across the whole range of battery percentage.
TIA.
9 Comments
pankajur
Galaxy Note
https://youtu.be/RWt5_nyQQtc
raja43sh
Galaxy Note
same problem I'm facing after latest update of security patch
SuperSU
Galaxy Note
Let's see if it is a common problem
Shiv9564
Galaxy Note
Have you tried Factory data reset?
SuperSU
Galaxy Note
No. Because I don't want to lose my data. But I shall do it if no help comes from here. It us my last option. Also, right now I wnt to know if my guess that this is a software issue then there must be other people suffering from this.
Galaxy Note
It's same problem with my handset as well. As it hits 5 per cent, takes only minutes to die down. I am also searching for solution of this problem.
SuperSU
Galaxy Note
If a few more such problems come up then this is definitely a software issue.
Francis
Galaxy Note
This is a common problem, the recent update could have corrupted your battery info in the dalvik cache.
Resolution
1. You can reset the phone (Full factory reset)
2. Caliberate your battery -
charge the phone to 100% and drain it all the way down to 0% do not charge in between. once 0% turning on the device until the battery is drained to flat 0% and there no juice left.
charge the phone back to 100% without turning on the phone. Once fully charged, remove the charger and power on the device. charge the device for another 5 min and you are good to go.
admin_
Galaxy Note
Thank you for sharing your concern. The relevant department will serve you better, if you can provide logs/video within 15 minutes of issue occurrence by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports). Be sure to hit ♡ when you find an answer that works for you.
For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
