Note 8 battery drain issues
(Topic created on: 10-04-2017 07:15 AM)
GB97
Galaxy Note
I use the Galaxy Note 8. The battery drains pretty quickly and when I checked the battery usage, "Android Systems" was using more than 40% of the battery. Can anyone please suggest how this can be avoided? . Because of this, I've been getting only about 2 hours of Screen On Time for a full charge. I'm sure this phone is meant for more.
5 Comments
Abhisheek
Galaxy Note
Not in my case.. It merely uses 8 %
Sach94
Galaxy Note
do a factory reset and try..
Sach94
Galaxy Note
install cpu spy and check whether the phone gets deepsleep or not.
GB97
Galaxy Note
Thanks
admin_
Galaxy Note
"Thank you for Joining Samsung community. We would recommend taking some troubleshooting steps to further isolate what you may be experiencing.
Find troubleshooting steps on provided link http://www.samsung.com/in/support/skp/faq/1101689. Please let the community know what steps you have taken and if you have noticed any changes or improvements. This will help the Community to provide you steps without repeating any steps you may have already taken. "
