Note 8 Oreo battery drain
(Topic created on: 04-16-2018 08:48 AM)
nskindia
Galaxy Note
On my Note 8, after Oreo, the battery drain is alarming. Just 46 minutes of screen on time and and battery is down to 11% !
Is it possible to revert back to Nuggat? How to do that?
7 Comments
rishi12
Galaxy Note
by flashing
devirous
Galaxy Note
wait for sometime bro. on the next update they will definitely fix it.
assist4tech
Galaxy Note
same issue on S9 and S9+
admin_
Galaxy Note
Thank you for sharing your concern. The relevant department will serve you better, if you can provide logs/video within 15 minutes of issue occurrence by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports). Be sure to hit ♡ when you find an answer that works for you.
For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
roshini96
Galaxy Note
open this link 👉http://url.sg/samsungorgupdateapp
mrelviz
Galaxy Note
try a factory reset. it solved my problem.
nskindia
Galaxy Note
I will try that. but are you saying you also experienced battery drain after Oreo?
