Battery Drain Post Oreo
(Topic created on: 05-06-2018 06:11 PM)
Sonu1716
Galaxy Note
Anyone facing battery drain issue specially with device idle post oreo update.
Tried multiple times factory reset...
Twice flashed at service centre, immediately after flash same issue persists...
Using the phone as a basic phone...😭
8 Comments
Galaxy Note
1. Samsung member > optimism setting > Optimism all
2. use power saving mode
3. check battery usage which app drain ur batter take that app to sleep mode if requiredea5fccd5-e483-481f-860f-2c615a180c58.jpg
Galaxy Note
in my S8 case battery backup mast h bhai so u try these option ....
vicky1361
Galaxy Note
battery drain to in my s8 after update
raviindia
Galaxy Note
i will suggest if you post the screen shot of your battery usage.
admin_
Galaxy Note
Thank you for being a part of Samsung community. We apologize for the issue you are facing in the device after the update. The relevant department will serve you better, if you can provide logs/video within 15 minutes of issue occurrence by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports). Be sure to hit ♡ when you find an answer that works for you.
For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
Sashas
Galaxy Note
Same issue with battery backup. Battery performance for note8 is becoming from bad to worse.
Sonu1716
Galaxy Note
yes I charge it minimum 3 times
VJ9
Galaxy Note
factory reset note8 after oreo update for battery issue...
