Camera problem in flash
(Topic created on: 11-02-2019 10:02 PM)
Reja4u
Galaxy Note
Please check picture. Is there any solution?
Galaxy Note
it seems like there is a hardware problem in camera, visit service centre for support.
Galaxy Note
@Reja4u is there any protective cover in camera or flash( like plastic cover which came sticken to it)?
Reja4u
Galaxy Note
no
Reja4u
Galaxy Note
Reja4u
Galaxy Note
ok :(
Pradiprajak
Galaxy Note
open your mobile cover
Galaxy Note
there is no issue with ur camera or flash. it's the same with all note 9. Carefully check, flash on note 9 is on right side, wen we take images with rear camera flash effect reverses and more impact of flash goes on left side of the subject which we click. But this blue tinge or glare comes only wen subject is exposed, I mean wen u click pic from distance.Try clicking image with flash of a close object or person, there won't be any glare. I m sure. I went to service centre few months back , counter checked the issue with other note 9 they had there, it was same with other devices too. Need not worry. No software , no hardware issue.
Galaxy Note
Samsung shud put flash light in centre in there future phones, to avoid this issue.
Reja4u
Galaxy Note
absolutely
Galaxy Note
Just click an image of ur hand with flash ON. If u don't find any glare, everything is fine then. That's the best way to check. Reference image attached 👇
