Camera problem in flash
(Topic created on: 11-02-2019 10:02 PM)
Reja4u
Galaxy Note
Please check picture. Is there any solution?
22 Comments
Reja4u
Galaxy Note
there is nothing in the ba k... no back cover or lens protector dear.
Galaxy Note
chak kar
Coolshiva
Galaxy Note
dust in camera lense
Reja4u
Galaxy Note
no dear... full clean lens
Not applicable
Galaxy Note
try to take photography in normal light condition and check...because at night, sometimes if you apply flash then it can capture dust also and produce photographical noice...I think there is no problem with your device camera lence...it's all about lighting conditions and techniques of take photography.
Reja4u
Galaxy Note
i have tried several times and it remain same :(
Not applicable
Galaxy Note
then once go to Samsung service center..may be hardware or software issue...as per my knowledge, if camera is producing issue after reset device, camera settings etc...then better to go to authorized Samsung service center
Galaxy Note
can you attach one more shot using flash in very low light( nearly blackout)?
Reja4u
Galaxy Note
take a look at left side.... bluish
