Battery issue
(Topic created on: 04-07-2019 07:13 PM)
Pras1
Galaxy Note
After 0ne UI update, battery drains fast and comes for 15hrs only for normal usage. Even If the phone kept idle, it comes only for 20hrs.
Samsung  pls revisit the issue.
3 Comments
Fountainhead311
Galaxy Note
Yes - observing the same issue for my S9+ battery draining in unusually quick time. Fix it Samsung/Google.
HerculePoirot
Galaxy Note
Samsung is really bad with updates. My last Samsung phone was the S6 Edge. Was working absolutely fine, until the update came through. Totally wrecked the performance. And that was the flagship of the time. I'd abandoned Samsung for a good while after that.
kaneki
Galaxy Note
same problem with my s9😣 seriously that's such a drag
