Battery draining issue
(Topic created on: 02-08-2021 04:07 PM)
skmgzb
Galaxy Note
Battery drains very fast after updating one ui 3. I am using galaxy note 10 lite
4 Comments
infosage
Galaxy Note
go to service center and reinstall it. I'm using note 10plus and faced same issue which you facing now. After re-installing it in service center, my mobile working normal and battery problem solved.
Try it once...Thanks
AGP25
Galaxy Note
same device here...no battery drain...give the kernels time to adjust to the new settings...it'll be all fine ...the phone is now very smooth and fast ...it feels very responsive...so wait the drain will be solved as there are little bugs..that needs to be fixed
Samsung_Support1
Galaxy Note
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
Not applicable
Galaxy Note
same problem here. battery drain fast over night
