Battery draining issue
(Topic created on: 08-28-2022 12:39 AM)
KristianSaha
Galaxy Note
I have been using my Galaxy Note 10 Lite for about 18 months. The battery life was good until I installed One UI 4.1. It was a major change in battery life. I was getting 1.5 to 2 hours less battery life.😭
 And heating is free Thanks Samsung😒👍.
5 Comments
ashara-dayne
Galaxy Note
Same here! 😩
KristianSaha
Galaxy Note
VinodKumarvm
Galaxy Note
Yes after updating samsung galaxy note 10+is also has battery 🔋 drain issue samsung software engineer team please solve this issue
KristianSaha
Galaxy Note
Agree 💯
cs_member8
Galaxy Note
Dear Samsung member,
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
