Battery draining and heating issues after August Update in Galaxy Note 10 Lite.
(Topic created on: 08-18-2020 05:29 AM)
SAN402
Galaxy Note
My galaxy note 10 lite 8GB 128GB is getting heated and battery is draining in idle condition even in power saving mode without any apps working in background. It's started after August update. Any one facing the same issue here !!??
13 Comments
rajkm008
Galaxy Note
its usually happens problems like heating, lagging, battery drainage when we update our device to newer versionn or security patches...
AGP25
Galaxy Note
sir do you think samsung will fix this in a update, cause I'm new to samsung products
rajkm008
Galaxy Note
yes ofcourse Samsung will definitely fix the issues ....rest assured...
rajkm008
Galaxy Note
whenever your device shows updates available don't update it immediately whether it's is Os upgrading or security patches, you have to wait for other users experiences and device functionality like heating, lagging, battery drainage etc post update... you have to wait for stable version
rajkm008
Galaxy Note
Try these things to save your device battery
1. Settings >developer option >background process limit >choose no background process
2. Disable auto sync
3. optimise your device often using device care app
4. on device care app >battery >3vertical dots >settings > put unused apps to sleep
5.Disable always on the display
6. On the device care app>battery >disable background process which apps consumes most the battery
doing this things can may help your device battery last longer..
rajkm008
Galaxy Note
reset the device once (create backup before resetting the device) or wait for next software update hope Samsung will fix the issues, one more option there u can visit nearby Samsung service centre and they can help you to resolve the your device problem....
SAN402
Galaxy Note
Thank You
rajkm008
Galaxy Note
Galaxy Note
Its a Common is in Exynos
