Galaxy note 10 lite overheating and battery draining fast after 4.1 update.
(Topic created on: 04-21-2022 01:15 PM)
Vinaywristle
Galaxy Note
Dear sir,
This is vinay from India, Telangana. I am using galaxy note 10 lite device since 1 year there I didn't noticed any heating and battery drain issues while using Android 12 4.0 update. But after updating to 4.1 update last week I noticed that the device was overheating around 46 degrees and battery draining quick even on phone calls and normal browsing at room temperature i.es around 28 degrees temperature never before. I request Samsung India to release an OTA update soon to overcome this galaxy note 10 lite device overheating and battery draining issue.camera performance also became very poor and not upto the mark after 4.1 update. Expecting to make samsung to work on this and pust the OTA update ASAP.
Thank you...
7 Comments
CODM6567
Galaxy Note
Enable adaptive power saving and put apps in deep sleep
Vinaywristle
Galaxy Note
Yeah thank you for the Reply but I was doing the same doesn't work
CODM6567
Galaxy Note
Then wait for the OTA update.
I have also seen that some Samsung devices are having battery drain issue after one ui 4.1 update like
A51, Tab s7+ and tab s7 fe, A52, Note 10 series etc. Samsung should work on this.....
cs_member8
Galaxy Note
Dear Samsung Member,
We acknowledge your query and apologize for the same. Please visit this mentioned link to resolve your device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
ROYTULIP86
Beginner Level 5
Galaxy Note
Facing the same problem
Akhilraj22
Galaxy Note
Facing the same issue
monu1989
Galaxy Note
Same here
