Battery drain
(Topic created on: 05-14-2022 10:03 PM)
bobbiee
Galaxy Note
My note 20 ultra is draining too fast..like an bullet express I'm experiencing the worst ever ..not even getting for 5hrs it's too horrible even after factory reset the same
9 Comments
Not applicable
Galaxy Note
You should check battery health in diagnostic menu. You can also do same by calling samsung customer helpline they also do remotely for you.
bobbiee
Galaxy Note
It is showing gud...
bobbiee
Galaxy Note
saarang007
Galaxy Note
Seems some issue with Google Play Services only. Nothing else.
Clear Cache for that app. Or even Clear Data, then update from Play Store.
Swipe down notification panel, check every icon (feature) and turn off everything that's not needed. After Factory Reset, some extra features turn on automatically.Screenshot_20220516-093325_Device care_55261_1652673805.jpg
Neyaz123
Galaxy Note
Same problem new s22 ultra drain too fast and heating issue
abhikakkar
Galaxy Note
Same for galaxy note 20 only 6 months old battery drains too fast not even getting 5hrs of SOT
Amit_MR
Galaxy Note
You guys need to go to recovery, remove cache. Turn it on, turn it off. Recharge upto 100%. And then switch it on and use the phone till 0%. Again charge it to 100% keeping the phone on.
It will calibrate the battery.
bobbiee
Galaxy Note
Already done.....no..use
cs_member8
Galaxy Note
Dear Samsung member,
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
