Battery drain problems in Note 10 plus after one ui 3.0
(Topic created on: 01-16-2021 01:50 PM)
sbhavik91
Galaxy Note
I have already tried wipe cache partition even nearby scanning is off,Bluetooth scanning and Wifi Scanning is off but still battery is draining fast.
12 Comments
Lifehacker
Galaxy Note
Yeah the battery backup is very bad. It gets worse with each update.
IshanKumar
Galaxy Note
bro see the comment i have made in this post, it will help you
IshanKumar
Galaxy Note
do these settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
1. Settings>Connection>more connections settings> disable nearby device settings.
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> go to these 3 options below on by one
6. Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will shared data to show recommendation and suggestion which also cause battery drain
7. Go to settings > account and backup> account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
NinerLyfe
Galaxy Note
Noone should have to go thru all of what you are suggesting in order to get more battery life   Should not have to disable soo many functions   defeats the purpose of the phone and the apps   its a flagship phone, worth quite a bit of money that should be able to run however without the major battery issues
IshanKumar
Galaxy Note
after using the phone for 1 year 7 months, these changes are needed for longer battery life. if you do not want to do this, then adjust with the quick battery discharging
TimLee4839
Beginner Level 4
Galaxy Note
An obnoxious response.
The suggested changes are helpful.  But a phone should never lose HALF of its battery life with a software update.  Total incompetence by Samsung.
IshanKumar
Galaxy Note
my dear, after 1 year and 7 month of usage, the battery looses it original strength, it's maximum charge capacity decreases, it's not due to a software update, it's the battery that wore out after a usage of 1 year and 7 month. i hope this message with please my dear obnoxious @timlee4839
IshanKumar
Galaxy Note
making changes according to the 4th point, will help a lot
NinerLyfe
Galaxy Note
This link does not show how this will help Note 10+ 5G or higher with the One UI 3 update and horrible battery life ....please advise   thank you
ever since i received the update mentioned above our phones are dying very quickly ...
