Battery drain issue
(Topic created on: 06-07-2020 06:09 PM)
Tharun3
Galaxy Note
My Battery is draining so fast that too the first five percentage and last five percent.  How to fix this??
6 Comments
Masakali
Galaxy Note
reset & disable Google app
Samvelsam
Galaxy Note
Use Power Saving Mode option, It Helps you to Save battery life.
Not applicable
Galaxy Note
which series of Note?
Tharun3
Galaxy Note
note10plus
Not applicable
Galaxy Note
exynos hai bhai if you play pubg it will drain the battery faster
Samsung_Support3
Galaxy Note
Dear Samsung Member,
Please visit this mentioned link to resolve your device battery drain issue: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
