Battery Problem
(Topic created on: 10-28-2020 09:29 PM)
Amir51
Galaxy Note
I had purchased my Galaxy note 9 in December 2018. And just after 6 month, my Battery backup started to decrease. It does not even stay for 6 Hours after full charge till 15%.
4 Comments
Ehsank
Galaxy Note
if you not done yet then do some settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
1. Connection>more connections settings> disable nearby device settings.
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> go to these 3 options below on by one
6.  Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will  shared data to show recommendation and suggestion which also cause battery drain
7.  Go to settings > account and backup> account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery?)
10. Google >click on 3dot at right top corner>usage and diagnostics >off this option.
Amir51
Galaxy Note
Thank you for your response. I'll do as you suggested.....!!!!!
Dilli
Galaxy Note
Battery is dilapidated. Its time for you to replace. These are signs of bad battery. Nothing else will help. Visit SC. Rs 1500 to 1700 approx 🤪🤪
cs-member13
Expert Level 4
Galaxy Note
Dear Samsung Member,
To resolve "Battery drainage" issue kindly follow the given below step:
>>Battery optimization: Settings>Select Device Maintenance/Device Care>Optimize>Optimize all options like Battery, Storage and Memory
For more information on battery drainage please click on the link below:
http://www.samsung.com/in/support/skp/faq/1101689
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report/ask question).
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
