Battery Issue
(Topic created on: 08-13-2020 12:07 PM)
Uditjain97
Galaxy Note
The battery draining issue is rising on my note 10 lite even after August update
5 Comments
Ehsank
Galaxy Note
u can do these settings to save more battery life
1. Connection>more connections settings> disable nearby device settings
2. Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
3. Google >click on 3dot>usage and diagnostics >off this option
4. developer option >background limit>no background processes.
5. Long press on each app specially 3rd party and rarely used app>app info>
6. Device care>battery >select "optimised and adaptive power saving.
Steps to enable developer option
settings >about phone>software information >then u find build number >tap 7 times>then back to settings
and at end of settings one new option called developer option
click on it and find that option
Ehsank
Galaxy Note
after that go to settings >apps>Google >notification >disable all unnecessary notification as Google has huge notifications.
as u can see in image
Uditjain97
Galaxy Note
thanks
Ehsank
Galaxy Note
if my comments are useful for you then please
ACCEPT AS SOLUTION BY CLICKING ON 3DOT AT MY COMMENTS
Samsung_Support5
Galaxy Note
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
