Battery Issue Note 9
(Topic created on: 01-07-2019 01:58 PM)
SDRdanny
Galaxy Note
Is it only my note 9 that battery drains fast or anyone else has same problem.
8 Comments
anilpss
Galaxy Note
everyone having this issue bro if your phone is fall into water then if it drains heavily then you worried about it max screen on time for samsung note 9 is 5 to 6 hrs min 4hrs when u put it in auto brightness
swapbiswas
Galaxy Note
6 hrs is also great
SDRdanny
Galaxy Note
🤔.... thought perfect smartphone to have 😅
anilpss
Galaxy Note
bro may I know your screen on time for your note 9 goto settings and goto device management and select battery and click battery usage you will see the screen on time there
SDRdanny
Galaxy Note
bro its 2hrs 13min
purvesh02
Galaxy Note
i own note 9 and i always turn on my medium power saving mode after 40% try this see if it works.
because of the big screen size the screen takes a lot of battery.
SDRdanny
Galaxy Note
🤞let's see...
admin_
Galaxy Note
We apologize for the battery issue facing in the device.Performance of battery depends on various factors; any third party application, software glitches may cause trouble. Kindly follow below mentioned steps to overcome the issue.
1) We recommend you to charge you handset with original wall charger that came with your handset sales pack.
2) Kindly clean the charging point of your charger and battery with a dry and soft cotton cloth to remove unwanted accumulation of dust/waste material.
3) You can also check the charging process while device is in switched off mode.
4) We also suggest you to charge your handset with alternate Samsung Approved charger to exclude the possibility that current charger is not the root cause of failure.
5) Check whether Bluetooth, WI-FI, GPS, Bluetooth, NFC / S Beam, Tethering and Portable Hotspot is turned off when not in use.
6) Check whether the brightness of the device is set to minimum.
7) Smart Features in Flagship phones like Motion UI, Smart Stay, Air Gestures, and Screen Mirroring / Smart view etc. will drain battery considerably.
😎 Check Power Saving Mode (If available)
9) Auto Sync of E-mails, App data etc. will drain battery.
10) Multiple Applications running in back ground will drain battery power.
11) Network Fluctuation also drains battery.
12) Minimizing the back-light time would save battery.
13) Follow the standard charging procedure (i.e. charge a fully discharge battery in Switch-off mode up to 150 minutes.)
14) Periodic Software Update through KIES, FOTA or Smart Tool is intended to improve the battery life as well.
• (Setting>>About Device>>Software Update>>Update) update using 4G/3G/ WI-FI connectivity.
15) Check by Go to setting>Application Manager>Running>Stop downloaded application when not in use.
16) After doing the above procedure, kindly restart your device and check the performance.
17) Check the issue in the safe mode.
If issue still persists, KIndly provide logs/video within 15 minutes of issue occurrence by registering this feedback via Samsung member application i.e. Samsung member BETA app> BETA feedback>Sendfeedback>Error report>Collect log files>attach.
Be sure to hit ♡ when you find an answer that works for you. For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url https://community.samsungmembers.com/en_IN#/
