Battery Drain Issues
(Topic created on: 02-08-2020 08:01 PM)
Krishi
Galaxy Note
So..the thing is on my Galaxy Note 8 I've been experiencing some serious battery drain issues after the battery hits at 15% charge, the percentage of the battery drops like water dripping from a fully opened tap, and it literally went from 15% to 5% in literally no more than 30 seconds.....should this be happening with my device? Is anyone other than me experiencing this type of battery drain?
Device: Galaxy Note 8
System: Android 9.0/ONE UI 1.0 with 2020, January security patch installed
12 Comments
ABDEVILLERS
Galaxy Note
format
Krishi
Galaxy Note
can't do for some particular reasons
Mahmudul2020
Galaxy Note
optimised your phone daily. Check update daily, Unnecessary apps should be removed immediately. / The apps that you are not using regularly, remove the apps.
Krishi
Galaxy Note
already been doing that for days now
Sampadarao
Galaxy Note
Samsung devices aren't waste for battery backup.
Krishi
Galaxy Note
what are you trying to say?
Devv_007
Galaxy Note
It seems your battery is uncalibrated.
Do these steps-
Charge device to 100%
Unplug
Open dialer and Enter code- *#0228# and tap on Quick Start
Wait for display to come back on
Repeat 3x (see if the battery % on the diagnosis screen changes a lot, if it does do it until it mostly levels out. If it doesn't level out, replace battery)
Krishi
Galaxy Note
I'll give it a try
Galaxy Note
You battery is worn out
Get new battery installed and all issues will be fixed
battery health have gone below 70%
