Battery Drain Issue
(Topic created on: 03-10-2023 04:19 PM)
KishoreGutala
Galaxy Note
Battery is draining fastly in Note 20 Ultra after One UI 5.1 Update..
Only me or others also facing the same issue..
Any solution for this issue?
2 Comments
MuzikD
Expert Level 3
Galaxy Note
Not experiencing such ...
cs-member11
Galaxy Note
Dear Samsung member,
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
