battery drain/Android 11 update issue
(Topic created on: 03-02-2021 10:21 AM)
12galaxyuser
Galaxy M
Iam using galaxy m31 from last 3 months...when I purchased this product that time the battery was very good till 1 month. But after sometime the battery was draining faster it's not working like a 6000 mah 😫 it's performing like a 4000 mah battery.
After an update of Android 11 i thought the issue will be resolved but it's still happening same...and after update I'm facing issues for camera focusing, delay to pick up a call...
(Any one is there who facing same problem)
9 Comments
Ehsank
Galaxy M
for battery issue if you not done yet then do some settings to save more battery life and observe for next 1-2 days, it will give a noticeable difference
1. Settings>Connection>more connections settings> disable nearby device settings.
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
FOR ANDROID 11;
A. DEVICE CARE > Battery>Background Uses Limit > Put Unused App to Sleep
B. Device care>click on 3dot at top right corner>automation>adaptive power saving
C. Device Care > Battery> More Battery Settings>Adaptive Battery
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info(ibutton)>> go to these 3 options below on by one
6.  Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will  shared data to show recommendation and suggestion which also cause battery drain
7.  Go to settings > account and backup> Manage account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on weather settings (icon)> change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
vaish03
Galaxy M
after doing all this still my phone's battery drains..btw I'm also using samsungm31 since November
Ehsank
Galaxy M
what is sot you are getting? could you please share
12galaxyuser
Galaxy M
same 🙋🏻
Ehsank
Galaxy M
regarding camera you can reset settings inside camera setting
Not applicable
Galaxy M
Reboot the handset
This is the quickest, easiest, and least destructive thing to try first. On most handsets you just press and hold the power button until the Restart option appears.
Update your apps
Don't have your apps set to update automatically? A rouge app is a common cause for sudden and unexpected battery drain. Head over to the Google Play Store, update any apps that need updating (updates come around fast), and see if that helps.
Update Android
OK, I know. Depending on the maker, updates can either roll around on a regular basis, or be as rare as hen's teeth (which might not be as rare as Android updates on some handsets).
But it's worth a try -- fire up the Settings app and go System > Advanced and then either look for About phone or About tablet or System update or Wireless update. You may well have to dig about!
Nuke your settings!
This is the nuclear option because it will mean having to set up your phone again. Make sure you have a backup of your data before doing this.
Most people can access the reset options by firing up the Settings app and going System > Advanced > Reset options. However, some handsets require you to press the power button and some combination of the volume up or down to make this happen which you might find through trial and error (warning, this is frustrating!) or from an internet search.
New Application issue
If you have installed any new application on your mobile, then that application can cause battery drain issues. Firstly, the best option is to uninstall that new application. To uninstall the application, go to the Settings menu. Now, click on the Application Manager. After that, find that application and uninstall that App.
sudip2001
Galaxy M
turn off always on display. it consume more battery.
Samsung_Support1
Galaxy M
Dear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
12galaxyuser
Galaxy M
there is no option for Android 11....and the resolution part is already done by side.
