Samsung galaxy m31 restart problem while using
(Topic created on: 06-11-2021 01:24 PM)
galaxy123
Galaxy M
My samsung galaxy m31 get restart while using .I have using since July 2020 there is no problem like this but near one month it creates problem.unless everything is right
PanditjiM31s
Galaxy M
Samsung Member app not installed in M31s, when i tried to search on Play store it show not compatible with your (M31S).
This is my primary device, i do all day to day works on this only.
Kindly suggest the solution asap.
sharadpatil20
Galaxy M
HI Samsung Team,
Samsung M31 hang and Restarting frequently.
This is happening when we try to use Camera (most of the time).
I have all the latest updates.
Request you to do the needful ASAP.
Thanks,
Sharad Patil
9820459476
sharadpatil20
Galaxy M
Done. Ran in SAFE mode it worked fine for 3-4 days and again issue is coming. Please suggest permanent solution.
Thanks,
Sharad
Nivedita7
Galaxy M
Same with my samsung m31 from the past one week. Service centre asking for around Rs. 8k for motherboard replacement.
ameen7
Galaxy M
Using period 1 year or
Same issue in my device 1 year 1 month only usung
sharadpatil20
Galaxy M
Have you got any solution ? Now it is restarting in few hours.
Thanks,
Sharad
vickycheeku
Galaxy M
Previously I am facing the restart issue today I have update the software after that also facing the same issue...anyone any idea for the this issue
Samsung_dSPqKeB
Galaxy M
facing the problem since yesterday. after every 2 mins phone restarts. Also did factory reset, hard reset but still no luck. Also tried disabling and rolling back updates for Android System Web View app as suggested by @SamsungUS on twitter.
rubin980
Galaxy M
M31 frequenly restarting
ameen7
Galaxy M
Same issue after last update . While using device was stuck then automatically restart. Sametimes reboot logo stuck only showing logo. Software bug or board issue
Purchased july 3rd 2020 only using 1 year 1 month how to crash board worst board & Software???
