Problem of M11 bluetooth sound
(Topic created on: 07-25-2020 02:52 PM)
BIG76
Galaxy M
I have purchased M11 set on 17.07.2020. My bluetooth sound is very low even if I have set it at maximum. My bluetooth external speaker's sound also coming low even if I have turned the knob to maximum. Request Samsung to solve my issue.
9 Comments
Abdul_Rahman
Galaxy M
Which brand bluetooth speakers you are using ?
BIG76
Galaxy M
iball karaoke barrel
Abdul_Rahman
Galaxy M
so it can your bluetooth speaker problem may be
BIG76
Galaxy M
No no it is working nicely when pairing with other mobiles
Abdul_Rahman
Galaxy M
I also using Samsung Galaxy M 11 Smartphone only but my device easily get connected to bluetooth speaker and volume also get high
BIG76
Galaxy M
That means my device has some manufacturing defect...
money1997
Galaxy M
yes you are right even m11 speakers are sounds so low then other device i m also getting the same problem
cs-member13
Expert Level 4
Galaxy M
Dear Samsung Member,
To resolve Bluetooth issue kindly follow the given below steps:-
1. Reset the device: -Kindly create data backup of your device via SMART switch mobile application or http://www.samsung.com/in/support/smartswitch pc suite.
Tap on Settings>Tap on General Management>Tap on Reset.
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report/ask question).
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
telu29
Galaxy M
Hi, I'm using samsung m11. When connected to Bluetooth and talk on calls the voice is getting unclear and getting noisy voice. But when listening to songs it is good.
