Dolby atoms not work and sound quality is very bad after one ui 7 please fix thi
(Topic created on: 07-08-2025 04:07 PM)
dipeshyadav
Galaxy M
🥵🥵 please help 🙏 glaxy m 35 sound very poor after one ui 7 my ear 👂 are very afacted please 🙏 give update for Dolby atom for m 35
2 Comments
cs_member10
Galaxy M
Dear Samsung Member,
● Check app cache: Settings > Device care > Storage > CLEAN NOW.
● Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
● Check device volume settings: Tap on Settings > Sound & vibration>Volume > Drag the volume adjustment bar left or right to increase or decrease the device volume.
To verify, play music and check the music sound. If the sound quality is good, then your speaker is working fine.
● Clear Adapt sound data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Adapt Sound> Storage> Clear data.
● Reset app preferences: Settings> Apps> Three dots> Reset app preferences> Reset.
3. If you do not remember password then advise to reset (Forgot password) your Google account.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send).
dipeshyadav
Galaxy M
Sab kuch kar ke dekh leya nhi thik ho rha hai
