Battery drain issue in M34 5g
(Topic created on: 06-20-2025 12:48 PM)
HemanthSuresh
Galaxy M
After updating the One UI 7 in Samsung m34 5g I have found lot of lagg , heating issues and Battery drain issues in last 3.5 hours 50% battery was drained out even device contains 6000mah battery.
Performance was totally down graded and lot of lag in switching from one to another app
Please samsung please fix this issue as soon as possible
13 Comments
Ashish_k_gupta
Galaxy M
After updating the one ui 7 my samsung galaxy a14 5g also heating and battery draining fast...it's not good experience on one ui 7 my one ui 6 is better than this...
BiRdMaN
Galaxy M
Send an error report along with log files to customer support through this members app and Samsung will fix it in the next update
If you find this helpful please mark it as Solution Thanks 😊
souvik22ff
Galaxy M
Same issue on my m34 i am using wifi but battery drain fast after one 7 update
BiRdMaN
Galaxy M
This can be due to the phone re-optimizing itself after the update or apps needing to be optimized for the new firmware.
Add apps to the "deep sleep" list to prevent them from running in the background and draining battery.
Clear app cache to remove temporary data that can impact performance and battery usage.
Resetting battery statistics can sometimes help.
Adjust background usage limits in Settings > Battery and device care > Battery > Background usage limits.
Choose options like "Put unused apps to sleep" or "Sleeping apps" to restrict background activity.
If you find this helpful, kindly accept it as a Solution. It helps others
Tap the 3 dots on my reply and select "Accept Solution." Thank you 😊
Rickydisouza
Galaxy M
Stop spamming in Every post bro ..you also that this things are not going to work..and everybody does this basic things
Rahulrkstr
Galaxy M
Same issue with my S23 Ultra please solve this
Tech-knight
Galaxy M
goodthings
Galaxy M
Kindly complaint to Samsung customer support through Samsung members app as error report also send log files along with this error report for this issue and wait for next update maybe fix it by Samsung team soon. If you like Please accept as a solution it's help to other users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Galaxy M
You're welcome to here.
