Battery drain issues
(Topic created on: 07-14-2025 09:18 PM)
Kingsburry
Beginner Level 4
Galaxy M
Battery drain issues is crazy in m34
4 Comments
goodthings
Galaxy M
Kindly complaint to Samsung customer care support through Samsung Members app as error report also send log files along with this error report for this issue and wait for next update maybe fix it by Samsung team soon. If you like please accept as a solution it's help to other users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Galaxy M
You're welcome to here.
BiRdMaN
Galaxy M
Send an error report along with log files to customer support through this member's app, and Samsung will fix it in the next update. To do that, follow this procedure
Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
If you find this helpful, please Accept it as a solution. It helps others. Thank you 😊
cs_member10
Galaxy M
Dear Samsung member,
3. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
9. Update software: Go to Settings > Software update > Download and install > Check for software update > If Software update available > Download > Downloading updates > Install now
10. Reset the device:
IMPORTANT:
• For this:
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
