Battery drain issue after Update
(Topic created on: 08-02-2025 08:49 PM)
Warn
Galaxy M
Hey Samsung team,
Basically I updated my phone with the latest security path on July 1, 2025. After updating my phone, my battery drains a lot. Before the update, I used to get approximately 10 hours screen on time with 100% to 0%. That means every 5%, I get 30 minutes in daily task usage. But now it downgrades to 7-8 hours, which is not satisfactory despite having a 6000mah massive battery. Please fix this problem. We the consumers chose this phone; one of the main reasons is a large battery inside. Please fix this as soon as possible.
There is no need to show my phone to my nearby customer care. My phone is quite good. Just needed to get a refined update.
4 Comments
goodthings
Galaxy M
Kindly complaint to Samsung customer care support through Samsung Members app as error report also send log files along with this error report for this issue and wait for next update maybe fix it by Samsung team soon. If you like please accept as a solution it's help to other users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Galaxy M
You're welcome to here.
BiRdMaN
Galaxy M
Send an error report along with log files to customer support through this members app, and Samsung will add/fix it in the next update. To do that, follow this procedure
Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
If you find this helpful, I'd appreciate it if you could ACCEPT it as a SOLUTION. Thank you 😊
cs_member10
Galaxy M
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
