Samsung m35 battery draining issue
(Topic created on: 4 weeks ago)
princekanaujiya7267
Beginner Level 3
Galaxy M
There are too much draining in m35 after one ui 7 update overall sot is 5 to 5.5 hours on basic usage and there are too much lag too
6 Comments
bigthinker
Galaxy M
Yes
cs_member8
Galaxy M
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
goodthings
Galaxy M
goodthings
Galaxy M
You're welcome to here.
Ragulk-007
Galaxy M
1. Update your software.
2. Reduce screen brightness.
3. Adjust display refresh rate to standard mode.
4. Turn off connectivity.
Disable Wi-Fi, GPS, and Bluetooth when not in use.
5. Turn off AOD.
If you like this solution.
Please
Accept as a solution .
Ragulk-007
Galaxy M
1Remove third party apps
or
Put in deep sleeping which apps not in regular usage.
2. Uninstall extra apps
3. Battery optimization.
4. Closed all background applications
Please
