11 Comments
- « Previous
- 1
- 2
- Next »
MrJaan
04-23-2018 12:31 PM in
Galaxy J
sir update krte ho to best hona chahiye na pr always new issue aa jata
harriya
05-31-2018 01:32 PM in
Galaxy J
Solution1:-uninstall (clear data first,then uninstall)and force stop(clear cache first then force stop) unused and unusual apps, clear caches, clear RAM, optimizing battery by putting apps sleep, force stop or disable unused useless preloaded apps...samsung apps,Microsoft apps and Google apps like chrome as it consumes more Ram and background data which results in heavy battery drain,,instead use browser, browser will take less Ram..(eg..via browser under 500KB)..clear or delete useless folder or duplicate folder in file manager... don't install apps from other stores and sites, it will cause your phone damage ..if you install these apps then uninstall it.....Solution2:- change your data cable(good quality wire) do all these things atleast once a day for best results....apne phone ko update maat karo jab aapka phone thik chal raha h to... update karne se phele 1 mahina ruko or dekho logo ke reviews update ke bare me agar thik hai to.... phir update karo...nonstop phone use karne se bhi problem aati hai isliye phone ko 2..3 din minimum use karo....
- « Previous
- 1
- 2
- Next »
