Battery Problem.
(Topic created on: 02-10-2017 07:28 PM)
SidShetty9079
Galaxy J
I m using Samsung Galaxy J7 Prime.Company says its 3300 mAh but it didn't give me perfect results.The battery drains very fast.I m very much irritated with this draining problem.
9 Comments
pprakash
Galaxy J
hllo it depands on the way you use your device : like low network areas, intall unusual apps or any other. never install battery related apps like battery doctor , power saver etc. they are critically harm to your device battery.
if battery is draining abnormally you cAn contact our nerest servicing centre. Thank you
WE LOVE YOU SAMSUNG
Samsung_India_
Galaxy J
"Thank you for Joining Samsung community. We would recommend taking some troubleshooting steps to further isolate what you may be experiencing.
Find troubleshooting steps on provided link http://www.samsung.com/in/support/skp/faq/1101689"
SidShetty9079
Galaxy J
but the battery drains when i start using Internet with 3g/4g spped.
battery drains fast.
DoctorStrange
Galaxy J
Restrict background data, it might help. However, please note that you won't receive notifications from some apps.
rishi12
Galaxy J
hello i am using smasung j7 prime it full charge in 4.30 hours
rishi12
Galaxy J
its very annoying
SidShetty9079
Galaxy J
still the same problem
msd7781
Galaxy J
https://youtu.be/lkblnjBou2k try this i think it helps you
msd7781
Galaxy J
