Usb & Wireless Debugging problem
(Topic created on: 11-05-2023 12:29 PM)
monojit23
Galaxy F
Why am not able to turn on usb and wireless debugging?
8 Comments
Samsung_OneUi
Galaxy F
Are you using beta?
monojit23
Galaxy F
Yes
Samsung_OneUi
Galaxy F
Thats why it is turned off default to secure your phone. Wait for stable version.
Galaxy F
I think your phone software is in testing version and not stable or beta version so file transfer may be locked
cs_member10
Galaxy F
Dear Samsung Member,
As per your query, we request you kindly share the log file. Without a log file, we cannot analyze this issue. This will help us to further investigate and resolve this issue.
To attach the log file: Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
monojit23
Galaxy F
Problem solved, it was happening because I turn on auto blocker in security settings..Screenshot_20231107_124100_Auto Blocker.jpg
ananth2004
Galaxy F
monojit23
Galaxy F
Turn of auto blocker from settings
