slow charging ,battery drain issues
(Topic created on: 07-12-2020 09:27 AM)
Samsung_NHAjFCv
Hi I am facing some issues in my mobile Samsung a50 after updated to June security patch.after updated my phone charging speed gets slow and battery drain faster plzz fix the problem
7 Comments
When did you received the update?
3 July 2020 at 4:34 PM
ADSoomeet
The complaint has reached the concerned department and is being looked at. A fix should arrive soon.
Pranu123
Yes same issue with my Galaxy a10s
Msngalaxy
Majority of samsung users reported battery drain issue because buggy update
Samsung m31 very slow charging
cs-member13
Expert Level 4
Dear Samsung Member,
We are very sorry for the inconvenience caused to you, please be assured and to resolve "charging" issue kindly follow the given below steps:-
1. Safe mode:- Power off the device > Press and hold the Power key for one or two seconds to turn on the device > When the Samsung logo appears, press and hold the Volume down key.
Note :-To exit safe mode restart the device .
2. Check charger functionality:- Request you to check the charger functionality with a different device or try to charge the same device with a different charger.
3. Reset the device:- Kindly create data backup of your device via SMART switch mobile application or http://www.samsung.com/in/support/smartswitch pc suite.
Tap on Settings>Tap on General Management>Tap on Reset.
For information on battery drainage please click on the link below:-
http://www.samsung.com/in/support/skp/faq/1101689
If the issue still persist, kindly register your concern in Samsung Members app (Samsung Members app > Get help > Feedback > Error report) along with Screen-shots(time taken to charge). This will help us to further investigate and resolve your concern.
Note: Please send device log files within 15 minutes of issue occurrence along with the exact issue details.
