Highlighted
My device is galaxy A50 my 15w charger was complainted 4 weeks ago now iam using 10w charger. And battery draining fastly now. is this a reason for draining battery faster? I dont know about it please respone my question
11 Comments
Highlighted
Are you using the original charger?
Highlighted
no original was complainted
Highlighted
what do you mean by complainted
Highlighted
its bricked
Highlighted
not working bro
Highlighted
Try optimizing your device through Device care and putting the 3rd party apps to sleep when not in use this will help you conserve battery.
Highlighted
No use bro
Highlighted
there is any chance to battery draining using 10w charger is this a reason?
Highlighted
No bro. But it is advisable to use proper cable and charger.
