03-17-2021 09:35 PM in
Galaxy A- Mark as New
03-17-2021 09:36 PM in
03-17-2021 09:54 PM in
03-17-2021 09:59 PM in
03-17-2021 09:56 PM in
Galaxy Ahttps://r2.community.samsung.com/t5/Galaxy-A/recovery-mode/td-p/7577849
03-17-2021 10:21 PM in
Galaxy A1. Settings>Connection>more connections settings> disable nearby device settings.
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
FOR ANDROID 11;
A. DEVICE CARE > Battery>Background Uses Limit > Put Unused App to Sleep
B. Device care>click on 3dot at top right corner>automation>adaptive power saving
C. Device Care > Battery> More Battery Settings>Adaptive Battery
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info(ibutton)>> go to these 3 options below on by one
6. Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will shared data to show recommendation and suggestion which also cause battery drain
7. Go to settings > account and backup> Manage account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on weather settings (icon)> change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
03-20-2021 10:57 AM in
Galaxy ADear Samsung Member,
To resolve your device battery drain issue please visit this link: https://www.samsung.com/in/support/mobile-devices/samsung-mobile-battery-drain-issue/
For further assistance, register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report/Ask questions).
