Poor battery, Call problem, Network related issue in wifi
(Topic created on: 05-30-2025 03:58 PM)
AdiGarg
I am experiencing issues with my Samsung Galaxy A55 5G after updating to One UI 7, specifically:
1. WhatsApp calls automatically muted during incoming calls, and
2. Wi-Fi disconnects suddenly, while the same router works fine with other devices. and it shows conne ted without internet.
7 Comments
Kaustav_Ray
Expert Level 3
Clean the mic (bottom hole). Test with Voice Recorder. If no sound, mic may be damaged or blocked by your case.
Kaustav_Ray
Expert Level 3
Remove SIM, clean it gently, insert again. Try the SIM in another phone. If still no signal, your SIM might be faulty or your SIM tray is damaged.
AdiGarg
Resolve my issue 🙏
goodthings
It's a major update reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your device wi-fi dropping issue.
Note: Before troubleshooting your device, you want to make sure that your cellphone is the only one having this problem on your WiFi connection. If all devices are having wifi issues, then you want to contact your internet provider as the issue is not with your device but most likely with your WiFi connection.
1. Navigate to the app's screen > Tap on Settings > Connections > Wi-Fi > Tap on the Wi-Fi network > Tap and hold the Wi-Fi network that you're having trouble with until the menu allows you to select Forget Network.
2. If the issue has not been resolved then restart the router and Mobile Device.
3. If the issue is still not been resolved, Reset the device:
IMPORTANT:
• For this: Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select ""try another way"" > Next > Enter a new password > Next.
Settings > General Management > Reset > Temporary cloud backup or External storage backup > tap on Factory data reset (This will erase all data, including files and downloaded apps)
However, regarding the whatsapp issue, we will surely try and help you with this. But since it is beyond our support boundaries we cannot support any third-party applications.
Kindly contact the respective application helpline. They will be able to provide you with the exact information about the issue.
