Galaxy A54 5G Battery Over Draining and Overheating Issue
(Topic created on: 05-15-2023 05:32 PM)
Not applicable
Even after installing may security update, the problems are still there .
Overheating like hell when we use it slightly in heavy usage.
Yesterday overnight idle drain was around 10% literally **bleep**.
Please Developers optimise this Exynos 1380 chip properly,
 I bought it for longer software support but how will it survive if it will perform like this ??
A Smartphone costing 40k should not be like this .
18 Comments
Mgmileshg
Exynos processorsnare known well for overheating over puny tasking. My A53 heated. I upgraded it to A73, now I'm fine.
But battery draining can be controlled. Go to device care in settings and tweak some setting. Turn adaptive battery saving on/off simultaneously and observe the heating issues. Keep using the phone as new ones tend to heat. Observe atleast for one month. If heating goes beyong 48°C, take it to a service centre, they are bound to get it fixed.
vivek1989
Mine
vivek1989
Chrome
Mgmileshg
Well, I can see clearly you were using Samsung internet.
vivek1989
Becoz samsung internet enables full dark mode which is good and chrome lags this feature.
It has dark mode but when u open web page ,the page is in light mode.
Mgmileshg
Agreed. Thanx for the tips and tricks. Nice talking 2 u👍
vivek1989
Mine is OK
1.enable safe mode
After every monthly update
Do the following
1.reset setting
2.recovery mode
Vipe cache partition
Mgmileshg
Greetings!
Won't resetting setting be a trouble for loosing all the manual setting I have done?
vivek1989
Thats the one possible way to clear cache and another safe mode it may fix ur problem
