Getting bugs and Back camera issues , BATTERY draining issue on S24 FE
(Topic created on: 09-27-2025 01:32 AM)
adityarathod16
Delhi
After one ui 8 Yesterday got my s24 fe got one ui 7 out of the box then recieved one ui 8 update .. battery draining fast will battery issue solve with time??
2 Comments
cs_member10
Delhi
Dear Samsung Member,
As you are facing multiple issues with your device, we kindly ask you to share the log file with us. Additionally, if you have any video clips or images that illustrate the problem, it would greatly enhance our understanding.
Path: Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.)
AphiptyTwoS
Delhi
aysa keh sakte hain
