Battery drain quickly for Samsung s25 plus after getting updated
(Topic created on: 05-20-2025 07:48 PM)
itsjitender
Delhi
I have been facing issue for Battery drain quickly after getting updated.
Due to that I need to charger my phone twice a day.
It does not make sense to face this problem in flagship phone.
3 Comments
goodthings
Delhi
goodthings
Delhi
Your's most welcome to here.
cs_member10
Delhi
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
