Battery drain issue after One Ui 7 update on Galaxy S23
(Topic created on: a month ago)
_anuragsaini_494
Beginner Level 5
Delhi
Hello Samsung Team,
After updating my Galaxy S23 to One UI 7, I’ve noticed a significant drop in battery performance. Earlier, the phone easily lasted a full day with moderate to heavy usage, but now the battery drains much faster even with light usage.
I've already tried the basic troubleshooting steps like:
Clearing cache partition
Putting unused apps to sleep
Turning off background data for non-essential apps
Enabling battery saver mode
Still, the issue persists. Kindly look into this and provide a fix or suggest any additional steps that might help. Hoping for an optimized update soon.
Thank you!
8 Comments
AmitSingh90
Delhi
Wait for next update
Delhi
2g
SammyBoyee
Beginner Level 3
Delhi
Same issue.. same phone model... what an update. 😂😂
yakinyadav
Delhi
Same issue 😪
BiRdMaN
Delhi
Yes, many users have reported experiencing similar problems. This can be due to the phone re-optimizing itself after the update or apps needing to be optimized for the new firmware.
Add apps to the "deep sleep" list to prevent them from running in the background and draining battery.
Clear app cache to remove temporary data that can impact performance and battery usage.
Resetting battery statistics can sometimes help.
Adjust background usage limits in Settings > Battery and device care > Battery > Background usage limits.
Choose options like "Put unused apps to sleep" or "Sleeping apps" to restrict background activity.
If you find this helpful, kindly accept it as a Solution. It helps others
Tap the 3 dots on my reply and select "Accept Solution." Thank you 😊
goodthings
Delhi
goodthings
Delhi
Your's most welcome to here.
cs_member10
Delhi
Dear Samsung Member,
As per your concern, you have already done the possible troubleshooting steps and the issue remains unresolved, we request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
