Battery Drain Issue (S24 Ultra)
(Topic created on: 04-25-2025 12:40 PM)
Tausif22
Beginner Level 5
Delhi
After Updating My S24 Ultra Battery Is Draining So Fast Without Any Use, Plz Fix It Fast.
5 Comments
SachChin
Delhi
Reset your device.... Mine is working fine
ashutosh165
Delhi
Mine battery improved significantly
goodthings
Delhi
It's a major update, reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Delhi
Your's most welcome to here.
cs_member10
Delhi
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
