3 weeks ago in
Delhi- Mark as New
3 weeks ago in
Delhi- Mark as New
3 weeks ago in
Delhi- Mark as New
3 weeks ago in
Delhi- Mark as New
3 weeks ago in
Delhi- Mark as New
3 weeks ago in
DelhiDear Samsung Member,
As per your concern, we would request you to kindly perform the following steps to resolve your issues.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
Galaxy device slow charging issue: https://www.samsung.com/in/support/mobile-devices/my-galaxy-device-is-not-fast-charging-how-do-i-fix...
Kindly follow the standard charging procedure. i.e. please charge the device in switched-off condition for 10 minutes.
Turn off Wi-Fi, GPS, Bluetooth, etc.
Turn off unused functions like Wi-Fi, GPS, Bluetooth, and location settings when not using them: On the home screen swipe down the notification panel > Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
Kindly check if ''Multiple applications'' are running in the background of the device.
When running multiple applications, the processor processes more tasks and as a result, additional heat is released from the device. This happens with most electronic devices (even computers/laptops), including the devices of other manufacturers. Close all the background running apps when not using them.
Avoid usage of mobile phones during charging. Usage of the mobile phone when charging may cause slow charging issues. So we recommend you avoid the usage of the mobile phone while charging.
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
If the issue still occurs, kindly report the problems using a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
2 weeks ago in
Delhi- Mark as New
2 weeks ago in
Delhi- Mark as New
Sunday in
Delhi![](/skins/images/7C5AC37FF183E6D8AB0928550016DA82/responsive_peak/images/icon_anonymous_message.png)
